savek
Jun 29, 2016Star
qBittorrent Web Client 1.0.3 cannot add large torrents
Hi all, I have installed qBittorrent Web Client 1.0.3 via the APP section of the Web Admin Console of my ReadyNas 204. It is all working good with one exception. I cannot add larger tha...
kohdee
Jun 30, 2016NETGEAR Expert
savek wrote:I cannot add larger than 5GB torrent files.
You mean your torrent is 5 GB, not the torrent file, right? I think the largest torrent file size I have in my meta folder is 2 MB.
savek wrote:When I select the torrent file via the web interface and click on the button "Download" , nothing happens.
So, is it add or download? You're using the qBittorrent to download the files that the client already downloaded? Or you're trying to add a torrent that has a total torrent download size of 5 GB and it never itself adds to the qBittorrent client?
BrianL2
Jun 30, 2016NETGEAR Employee Retired
Hi kohdee,
Most torrent files are less than 100kb and when I tried it on my end. I was able upload the torrent file via download/upload and magnet link but it won't start the download. The said torrent file to be downloaded is 7.6GB and when I tried a smaller one (1.xxGB and 100mb), the download started immediately. Not sure if this a limitation or what.
Kind regards,
BrianL
NETGEAR Community Team
