gjohnson71
Mar 03, 2021Tutor
RAID 10 Expansion
I have a RAID 10 using (4) 4TB drives. I was running out of space, so I added two more drive into the empty bay 5 and bay 6. I went into the volume, choose the two new drives and clicked "Expand". ...
- Mar 06, 2021
likeman wrote:
you cant change raid levels via the GUI unless that as changed
I don't think gjohnson71 is trying to change RAID levels, he is sticking with RAID-10. But he does want to expand to 6 disks instead of 4.
I am thinking (like you) that the expansion will show up when the resync is complete. But mdstat.log will show the details of how the RAID array is set up, and will also show us the sync status.
likeman
Mar 05, 2021Aspirant
gjohnson71 wrote:The sync is in process now.
expanded available space will not change until the 2 extra disks have finished syncing (going form 4 disk to 6 disk) it shouldnt take that long in raid 10 (as the mdadm has to add the 2 extra disks then the BTRFS filesystem expands to fill that new space, you cant have more space until sync/expand proccess has finished)
you cant change raid levels via the GUI unless that as changed (apart from raid5 to raid 6 but that is called add Party disk, x-raid must be turned off before inserting the new disk or it will auto expand with raid5 if its currant set to raid5 unless its the 7th disk then it auto converts to raid6 on the 7th disk plugged in)
Mar 06, 2021Guru - Experienced User
