Kadesh
Mar 27, 2017Aspirant
RAID 6
Dear All,
We bought new NAS316 with 6TB HDD X 4 and I have configured intial settings, but when i look at volumes it by default it is configured to RAID 5 but I want RAID 6 to be configured.
and how do i check how many HDD's are configured as RAID 5 because total usable space I am getting is only 18 TB (I have 6TB X 4).
Please help me in this.
That's the expected capacity for RAID-5. With RAID-5 you'd subtract the capacity of one disk for redundancy so 5x4TB = 20TB, but like most PCs we use TiB (base 2) not TB (base 10). So 20TB = 20/1024^4*1000^4 = 18.19 TiB which rounded down to the nearest TiB is 18TiB. Like PCs tend to we refer to TiB as TB. A bit confusing that we use base 2 whereas disk manufacturers use base 10 but it's still the same amount of space. Allowing for overheads 18TB is what you'd expect using RAID-5.
To change to using RAID-6:
1. Go to System > Volumes2. Disable X-RAID (click on X-RAID button and confirm you wish to disable it)
3. Destroy the default volume (note this wipes all the data, so be sure to backup your data first).
4. Create a volume called 'data' (no quotes) using all disks in RAID-65. Re-enable X-RAID.
- Retired_Member
mdstat.log is telling you this. you can download the logs by going to the admin webpage. use system/logs and click on the download button. this will generate a zip-file on the harddisk of your workstation. mdstat.log is part of that.
- KadeshAspirant
Sir,
Thanks for the reply,
I got HDD information but how do i make all the disks into RAID 6..??
Please revert
- mdgm-ntgrNETGEAR Employee Retired
- KadeshAspirant
Dear Sir,
Thank you for the help,
I followed the the steps and I am succeeded but I am not happy with available storage as it is giving only 10 TB.
I am ok with RAID 5.
but thank you so much for the help.
- Retired_Member
http://rdconfigurator.netgear.com/raid/index.html
gives a nice opportunity to compare available diskspace under different RAID levels
