NameAlreadyTake
Mar 23, 2022Aspirant
Raid X - Raid 10 RN628X
I'm looking to update my existing 4 bay RN314 NAS to a Readynas RN628X 8 bay NAS... For reference, I'm currently getting average transfer speeds to my existing RN314 circa 110-120MB-s over a 1Gbi...
- Mar 23, 2022
NameAlreadyTake wrote:
There apear to some RN628X's available at some UK suppliers. This model is also showing current on the Netgear web site. Is this not the case? Has it been superseded?
Thanks, JamesReadyNAS generally have been hard to find for quite a while, and there are rumors here that Netgear is exiting the NAS business. Netgear hasn't said, but it is very plausible - no new platforms introduced for some years, and recent firmware releases have been focused on maintenance/security fixes.
You might want to check the pricing on the units you are seeing with comparable Synology units. (FWIW, I've never owned a Synology, so this isn't a purchase recommendation. Just a suggestion that you check pricing from other vendors).
So am I right in assuming that if I start with 4x HDDs in the unit in raid 10 that I can add another 4 in later and it will expand the Raid 10 partition to fill all drives automatically while keeping all data?Expansion wouldn't be automatic, as you'd be using flexraid. You'd go into the volume settings, select the two added drives, and then click "Expand". Here's a link to a post from a user who's gone through this process: https://community.netgear.com/t5/New-ReadyNAS-Users-General/RAID-10-Expansion/td-p/2064928
Note you can add the new disks in pairs, you don't need to add all four at the same time.
Mar 23, 2022Guru - Experienced User
For reference, I'm currently getting average transfer speeds to my existing RN314 circa 110-120MB-s over a 1Gbit network using 4 drives in Raid 10.
Which is all the speed you will get on a gigabit network connection.
I can't find any stats for Raid-X. Please can anyone provide average read write speeds for Raid-X mode over a 10GBit network? I'm still to determine the drives that I want, so average based on standard NAS rated 3.5" magnetic disks circa 16GB are what I'd b looking to run with (Not solid state).
XRAID is just an application on top of software RAID that manages expansion for mdadm (standard sofware RAID for linux).
Performance will depend on exactly what disk setup you have.
- 2 disks - RAID-1
- 3-6 disks of equal size - RAID-5
- 7-8 disks of equal size - RAID-6
If disks are unequal in size, then the RAID configuration is more complicated - consisting of multiple RAID groups. For instance, 4x8TB + 2x16 TB will give you a 6x8TB RAID-5 group concatentated with a 2x8TB RAID-1 group.
As far as performance goes, this review might be helpful: https://www.storagereview.com/review/netgear-readynas-628x-nas-review Though it is more focussed on latency and iops, the bottom two graphs are throughput.
In addition, what are the benefits / negatives of Raid-X bar expandability
XRAID handles disks of different sizes automatically. To get max capacity out of the array, you need to ensure that the biggest 2 disks are the same size with single redundancy (up to 6 disks). The system switches to dual redundancy (e.g., RAID-6) when you insert disk 7. At that point the biggest 4 disks need to be the same size. Normally, you either replace a disk with one of the same size (to take one out of service), or upgrade to one that is either the same size (or larger) than the biggest disk in the array.
Overall, RAID-10 will give faster speeds (unless you are network-limited), but XRAID is generally simpler to expand.
NameAlreadyTake
Thanks.
Thanks.
