oikos's avatar
oikos
Follower
Jul 25, 2013
Raidiator 4.2.24 update
Hi,
After update my fw to 4.2.24 on ReadeNAS 2100, device disappeared from network. The network destination is unreachable. There wasn't any change in lan structure. What's more my AV reported after update some ARP spoofing attact from ReadyNAS IP. Did you know such problem? What can I do now to restore stable operation? I can log-in from directly connected pc. The IP address is the same. There are no special warnings in log. Everything looks fine. In addition, backups are executed on schedule, no disk smart errors. In http_errors.log I found once "[error] server reached MaxClients setting, consider raising the MaxClients setting" - but it was only once. By the way, where can I change that variable? It's going about apache httpd.conf? Thanks for any advice.
Tomasz Viscardi
ProSupport for Business
