kjedrusiazk
Jul 18, 2020Aspirant
RDN4000 v3 can't be seen on the network.
I actuall have v3 with 4 1TB drives installed and it has been working well. The cable company router took a power hit during a storm and blew out a network port, that it turn might have taken out...
- Jul 18, 2020
Though this is often confusing, as far as the forum is concerned you have a v1. More pedantically, you have hardware revision 3 of the original NV+. The "NV+ v2" is a different platform that uses an ARM processor instead of a Sparc. Your NAS runs 4.1.x firmware, the "NV+ v2" runs 5.3.x.
kjedrusiazk wrote:
The front screen shows the correct IP address.
Did you assign a static IP address to the NAS (in frontview)?
Have you tried RAIDar, and see if it can discover the NAS? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
kjedrusiazk wrote:
Are there even parts available for this unit? I would love to be able to retrieve the contents of the volumes,
Or is there a replacement device I could put the drives into that would recognize the existing data?
Netgear doesn't carry parts for it (and it went end-of-life back in 2011).
If you can connect the drives to a PC, (either with SATA or a USB adapter/dock) then you can get the data using RAID recovery software. https://www.r-studio.com/
If you are comfortable with linux, it is also possible to mount the array using linux command lines.
If you purchase a new ReadyNAS, Netgear paid support can temporarily mount the array, so you can offload the data. I don't know what they charge for that service. https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
Jul 18, 2020Guru - Experienced User
kjedrusiazk
Jul 19, 2020Aspirant
Grabbed RAIDar will see if that might find it and go from there.
Thanks!
