leo037
May 29, 2023Luminary
Issue with hard drive upgrade and xraid
Hi everyone, Hoping someone can lend some help and maybe provide a solution. I am helping a friend out with her ReadyNAS. She's not big on being on forums or social media so relaying things f...
May 31, 2023Guru - Experienced User
Sandshark wrote:
Hmm, that only accounts for 6 of the 8 drives, so something more is wrong.
leo037: The log zip you sent me says this is an RN316, not an RN428. So only 6 internal disks. Plus 5 more in the EDA volume.
boot_info.log:
vendor: NETGEAR
model: ReadyNAS 316
serial:
sku: RN316
loader: 4.6.5
board_rev:
system_rev:
reason: Normal
Something is odd here, as the serial, board_rev, and system_rev fields should be populated.
leo037
May 31, 2023Luminary
Yeah sorry it is actually a 316.
Serial number I removed
Not sure why board and system rev aren't there
I don't recall where she got this one from. Could have been a craigslist or ebay find
- SandsharkJun 01, 2023Sensei
So did the volume size increase with the second through fifth drive swap while the unit was still in XRAID? The data StephenB posted seems to indicate it did, and that would be expected. Unfortunatly, the inability to switch back to XRAID is completely normal, and I suspect the fact that the last drive isn't expand is also directly related to that.
If it did not expand at all, I cannot explain why. There may be a complex way to get it to do so by deleting all the "unused" partitions and the letting FlexRAID expand to all of them, but I've never tried that and destroying and re-creating may be best, especially since it can restore XRAID mode.
There is a complex method of manually doing the expansion via SSH. See How-to-do-incremental-vertical-expansion-in-FlexRAID-mode. But the unit will remain unable to go back to XRAID.
- StephenBJun 01, 2023Guru - Experienced User
No. The RAID group exists (with one missing disk), but BTRFS did not expand to use it.
I think unformating and then re-inserting disk 6 will likely fix it.
