xbmcgotham
Aug 12, 2021Tutor
Monitoring UPS over SNMP for Readynas nv+ v2.
Hi, I cant understand why the Readynas is not switching off when a low UPS battery level is reached. As you can see on the screenshots, I am monitoring a UPS over SNMP and it can ready the values...
Aug 12, 2021Guru - Experienced User
xbmcgotham wrote:
No USB available.
This is the Smart-UPS X 2200? The manual (attached) says there is a USB port.
xbmcgotham
Aug 13, 2021Tutor
Hi,
Its not completly the same as the document. mine is a SMX2200HV
The manual does look to show a usb, not sure why I never seen it. I will have another look on the UPS. :-)
Question:
1. why would I connect the NAS with the UPS using USB cable? Does this not defeat the purpose of the network monitoring option?
2 If all would have worked correctly without using a USB cable, what would be the value on which the NAS should switch off when using the network monitor option? Low battery? Any idea?
Thanks
- StephenBAug 13, 2021Guru - Experienced User
The idea is that you switch away from SNMP, and try using that alternate monitoring tool. If that works, it would give you a clean shutdown if the power were to fail.
In any event, as far as the NAS is concerned, there is no particular advantage I am aware of with SNMP over USB.
But I'm not sure that SNMP isn't working properly (see below)
I don't know (I use USB monitoring with a different brand of UPS), but I did look at the MIB a couple years ago. I believe it shuts down when the UPS sends a trap. I think you can configure the timing of that on the APC. https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Shutdown-rules-on-ReadyNas-Duo-V2-arm-with-connected-APC/m-p/1508811/highlight/true#M142436
One thing you could do to test your monitoring (either SNMP or UPS) is to connect the equipment to the main power temporarily, and then connect a test load onto the UPS (a fan, or anything that uses a fair amount of power). Then disconnect the UPS from the main power, and wait for it to completely drain. You can then confirm that everything shuts down cleanly.
- xbmcgothamAug 13, 2021Tutor
Thanks again StephenB I will have a try on the suggested steps.
I guess for now this case is closed as the OS is no longer supported.
CU
Just to clarify - this is a community forum, and I don't work for Netgear. I don't know if Netgear would offer paid support for your NAS or not.
