gso
Jul 12, 2023Guide
Netgear rn21200 NAS
Have new Mac computer & need to delete existing Time Machine backup to start anew.
- Jul 26, 2023
After I erased Sparsebundle, I was able to restart TM backup by clicking on "Enable" button to turn off (see attached pic), then immediately clicking on it again (to turn on). Type in new password, then click "Apply" & "OK". Started right up.
schumaku
Jul 22, 2023Guru - Experienced User
Define (or change) the password here https://kb.netgear.com/22810/How-do-I-back-up-Time-Machine-data-to-my-ReadyNAS-OS-6-storage-system
To back up data on your Mac to your ReadyNAS system using Time Machine:
- On the local admin page for your ReadyNAS, select Backup > Time Machine
Here you can define the password.
gso
Jul 22, 2023Guide
Where should my NAS & NAS afp be connected to in the finder window?
- gsoJul 23, 2023Guide
https://kb.netgear.com/31027/How-do-I-map-a-network-drive-in-Mac-OS-X
Hostname/Sharename--
IP address is Hostname
timemachine is Sharename
If your Time Machine backup is AFP, use this instead of SMB.
Click on timemachine in Finder window.
Right (control) click on Sparsebundle & choose "Move to Trash".
My Sparsebundle was huge & took hours to delete.
Re-choose backup Disk (I chose timemachine local drive, same as before).
I'm waiting to complete first Backup. Wish me luck.
says-"
The backup disk image could not be created. I give up for the day
- gsoJul 23, 2023GuideSparsebundle is erased, just need to figure out how to start backup (tried doing that in icon on top)
- gsoJul 26, 2023Guide
