AJSG1969
Dec 11, 2020Aspirant
Permission problems with Windows 10 Pro - ReadyNAS 2120 v2 - Office 365
Dear All, Since moving to Windows 10 Pro I am having significant permission issues with our ReadyNAS Share access. I have tried the basics but cannot seem to create a username/pass combination to ...
AJSG1969
Dec 12, 2020Aspirant
Edited Several Times! As I had forgotten to check "Folder Owner" and "Folder Group" in the File Access Menu
I cannot Connect the share via "Map Metwork Drive", Windows requires an email address and password and when I enter "AG" and "test" I get asked again for the User/Pass and get a pop up saying that the folder already exists. However no folder appears.
C:\net use
Shows no shares in existance.
If however I create the Netword drive by using:
C:\Users\AndrewJSGebhardt>net use t: \\172.16.105.196\Scan /user:AG test
I then created a brand new share called "Test", dumped 20Mb of files in there and ONLY changed Network Access to "admin" and "AG"
However via Windows I cannot get access to the whole share. I can only connect via command line. When I connect via command line everything works seemingly fine.
AJSG1969
Actually, using command line is 100 times better than File Manager, just set all the family shares in minutes.
Thank you for the help!
