tigerten
Jan 28, 2024Luminary
ReadyNAS OS 6.10.10 released
Link to download: https://www.netgear.com/support/product/readynas_os_6#download Release Note: https://kb.netgear.com/000065999/ReadyNAS-OS-6-Software-Version-6-10-10 Cleaned up a b...
Jan 31, 2024Guru - Experienced User
eton wrote:
"The Apps installation function is removed from the Apps section on the System page (also referred to as Overview page) of the Admin Page."
They also changed the apt configuration, so there are things you'd need to undo in order to use apt in ssh.
givememynamebak
Feb 15, 2024Luminary
They must have uploaded it to the upload server because I get prompted for this update and I was unaware of it until it prompted me. But, now I have questions:
- The Apps installation function is removed from the Apps section on the System page (also referred to as Overview page) of the Admin Page.
What does this mean exactly? I am not aware of any "Apps Installation" function from the "System - Overview" page. I'm only aware of being able to install only "Featured Apps" directly from that page. Normally if I want to install an app, I click the Apps tab then Upload. And I still install and upload apps often which are just docker apps that I can start and stop through frontview but uploading is a ReadyNAS plugin/app to install as the "latest" docker image to update. Are you saying if I update to 6.10.10, I can no longer install any app???
StephenB wrote:
eton wrote:"The Apps installation function is removed from the Apps section on the System page (also referred to as Overview page) of the Admin Page."
StephenB - What do you mean by this? I still install my own ReadyNAS apps that utilize docker and work just fine - why would they prevent this? (ie: Docker, GitLab, Heimdall, Logitech Media Server, Portainer, Sabnzbd, Syncthing, Vault Warden)
