martinhj
Oct 11, 2015Luminary
RN104 + 6TB
Ive just put the new 6.4.0 Firmware on my RN104's. Does that mean I can now use WD Red 6TB drives in here and not have the 16TB volume limit as that is what I understand from the release notes. T...
- Oct 11, 2015
The HCL has the comment for several 6 tb disks, not just the red.
Clearly they just need to update the list to remove the comment. The release notes for 6.4.0 state that >16 tb volumes are now supported, so by inference the disks are, (and were) supported; it's just that you can now create a volume bigger than 16tb whereas previously you could use the disks in a configuration where volume sizes were <16tb.
vandermerwe
Oct 11, 2015Master
- kohdeeOct 12, 2015NETGEAR Expert
There's a new HCL coming soon, so it can likely get updated around then.
