el_patron
Dec 21, 2019Tutor
RN314, snapshots do no start on one home share, but on others...
Hi there, I have a strange issue with the snapshots on one home folder. There the snapshots do not start, allthough a snapshot folder is present. In all other folders and shares on the NAS there is ...
- Dec 21, 2019
Did you ever have ssh enabled? If so, it is possible that /home/Ulrike was created with ssh?
I think this could also have happened if the home folders were restored with a backup before the user ever accessed the NAS with file explorer or finder.
One option is to copy off the files, then delete the user account and the folder /home/Ulrike. Then recreate the user account, and access the NAS with that person's credentials. That should re-create the share. Then copy back the folder contents.
Sandshark
Dec 22, 2019Sensei
Since snapshots are also subvolumes, I doubt you've gptten what you think you have. Your "snapshots" are likely full copies of the snapshot contents, not just mostly pointers to the unchanged data, And I have no idea how that is going to affect taking real snapshots.
AFAIK, there is no way to backup and restore or transfer a set of snapshots for a share except via ReadyDR, which still doesn't allow you to restore a share with it's snapshots intact.. It seems to be a BTRFS limitation, as I have looked outside of the Netgear GUI for a method and came up with nothing.
el_patron
Dec 22, 2019Tutor
Sandshark wrote:Since snapshots are also subvolumes, I doubt you've gptten what you think you have.
I think that was a misunderstanding. I only copied the empty snapshot-folder back, not including any snapshot, as this did not work anyhow before.
Some minutes ago I checked with hourly snapshot and there was one snaphsot established for the newly installed home share! I think it is working now properly. Thank you all for your support here.
BTW: in the mean time I noticed the possibility of manual snapshots for non-home-shares, but not for home shares...
- SandsharkDec 23, 2019Sensei
OK, so long as you are getting valid new snapshots, I think all is well. What I explained is probably why it didn't work to copy them back. That's better than it seeming to work and not being what you really wanted.
