SLK-Purdue
May 03, 2022Luminary
Unable to send Alerts via Sign in with Google
Google is making changes is the area and looks like latest ReadyNAS FW stopped being able to send Alerts with Google on May 1, 2022. Scott Model: ReadyNAS 312 Firmware: 6.10.7 Context: syst...
JeraldM
May 05, 2022NETGEAR Employee Retired
Hi SLK-Purdue,
It does look like an auth issue and I assume the most recent attempt was when you manually set it up, right?
In this case, would it be possible if you could try signing in Google using an incognito browser and if possible, removing all of the alert contacts as well?
JeraldM
NETGEAR Community Team
SLK-Purdue
May 05, 2022Luminary
yea, most recent attempt to manually sent.
I will try as you suggest and let you know.
ScottJeraldM wrote:
Hi SLK-Purdue,
JeraldM
