CRUZZIN7
Aug 17, 2019Aspirant
update rnd2150v2 from raidar 4.1.1.6 to raidiator arm 5.3.11
okay oldtimers...I need your help... I have a rnd2150v2 (yes v2 and for some reason it never shows up on any previous model). It is stamped on the back with a sticker rnd2150v2. Everything i...
- Aug 17, 2019
Raidiator 4.1.1.6 firmware is the correct firmware version for your ReadyNAS
Raidiator 5.3.11. is NOT, so do not even go there
bedlam1
Aug 17, 2019Prodigy
- StephenBAug 17, 2019Guru - Experienced User
4.1.16 :smileywink:
CRUZZIN7 The v2 label doesn't mean that you think it does. You have a sparc-based NAS (called a v1 here). The Arm based NAS (which does run 5.3.x firmware) would say "Duo v2" on the front chassis - not buried in the part number.
- CRUZZIN7Aug 17, 2019AspirantThanks for letting me know.
