Angusjdd
Apr 29, 2019Aspirant
Ready Cloud Backup Questions
I am a newbie user and using a RN422 with 2x4TB drives for local backups only, windows PC.
I have successfully installed the ReadyCLOUD app and have used it to create some backups. My aim is t...
Angusjdd
Hi Stephen
Thanks for the fast response. Appreciate what you are saying, I'll look at Acronis. I take it from your response that Readycloud backup cannot (easily) do what I am wanting. I guess being software from a hardware manufacturer it is not as feature rich as a dedicated package!
Apr 29, 2019Guru - Experienced User
My recollection is that it doesn't give you much flexibility in the folders it will back up, and also there isn't much in the way of options.
I'm sure there are folks who do use it, hopefully some of them will chime in.
