porcupineG
Mar 12, 2016Aspirant
Ready NAS 102 6.4.2 kernel config
Hi, can you provide working kernel config for ReadyNas 6.4.2? This one in arch/arm/readynas_defconfig is clearly wrong and modules cannot run on due to modversion. Regards!
- Apr 05, 2016
Hi,
it turns out that problem is not kernel config, but toolchain version, i was using arm-marvell toolchain. after changing to linaro toolchain, everything is working now!
Thanks for help!
porcupineG
Mar 31, 2016Aspirant
Gently reminder.
Has anybody compile external module for RN 102 with 6.4.2 software?
JennC
Apr 01, 2016NETGEAR Employee Retired
Hello porcupineG,
Have you checked at http://kb.netgear.com/app/answers/detail/a_id/2649/~/netgear-open-source-code-for-programmers-(gpl)?
- porcupineGApr 01, 2016Aspirant
Yes,
it is not working, as well as config from here: http://www.readynas.com/download/GPL/index.php?dir=readynasos%2F6.4.2
- porcupineGApr 04, 2016Aspirant
For example netconsole.ko module differences with modversion:
modversion dumps from netconsole.ko (module from 6.4.2 releas)
0xb0a0443b module_layout
0x71d9d714 unregister_console
0x5f8ed658 kmalloc_caches
0x9ef39631 register_console
0xd52e2ff7 kmem_cache_allocmodversion dumps from netconsole.ko (module build from http://www.readynas.com/download/GPL/index.php?dir=readynasos%2F6.4.2)
0x79a437c6 module_layout
0xf6dc2411 unregister_console
0xe0cde3cb kmalloc_caches
0x56efd496 register_console
0xa43bd559 kmem_cache_allocfrom my investigation there is difference with kmem_cache structure and module structure, however i still cannot find fitting config :(
- porcupineGApr 05, 2016Aspirant
Hi,
Thanks for help!
