porcupineG
Mar 12, 2016Aspirant
Ready NAS 102 6.4.2 kernel config
Hi, can you provide working kernel config for ReadyNas 6.4.2? This one in arch/arm/readynas_defconfig is clearly wrong and modules cannot run on due to modversion. Regards!
- Apr 05, 2016
Hi,
it turns out that problem is not kernel config, but toolchain version, i was using arm-marvell toolchain. after changing to linaro toolchain, everything is working now!
Thanks for help!
porcupineG
Apr 04, 2016Aspirant
For example netconsole.ko module differences with modversion:
modversion dumps from netconsole.ko (module from 6.4.2 releas)
0xb0a0443b module_layout
0x71d9d714 unregister_console
0x5f8ed658 kmalloc_caches
0x9ef39631 register_console
0xd52e2ff7 kmem_cache_alloc
modversion dumps from netconsole.ko (module build from http://www.readynas.com/download/GPL/index.php?dir=readynasos%2F6.4.2)
0x79a437c6 module_layout
0xf6dc2411 unregister_console
0xe0cde3cb kmalloc_caches
0x56efd496 register_console
0xa43bd559 kmem_cache_alloc
from my investigation there is difference with kmem_cache structure and module structure, however i still cannot find fitting config :(
porcupineG
Apr 05, 2016Aspirant
Hi,
Thanks for help!
