BenRedd
May 19, 2023Aspirant
Ready NAS 102 no longer accessable
Hello, I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to g...
May 19, 2023Guru - Experienced User
BenRedd wrote:I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date
Dec 2015 firmware, so yes - very out of date. Current firmware is 6.10.9. Did you ever update it?
BenRedd wrote:
I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to get to my data.
What status is RAIDar giving you?
You want RAIDar 6.5
What happens if you browse to https://nas-ip-address/admin? (using the real NAS IP address of course). Do you get a username/password prompt?
What happens if you enter \\nas-ip-address in the File Explorer address bar? Make sure you use the correct slash (\\, not //).
- SandsharkMay 19, 2023Sensei
There is no protection on the drives unless you set it up as an encrypted volume. But it's a Linux MDADM RAID with a Linux BTRFS file system on top, neither of which can be read by Windows natively. There are some beta drivers out there that purport to add that capability to Windows, but I've not tried them.
- StephenBMay 19, 2023Guru - Experienced User
I think we need to first confirm the NAS status as best we can. It's quite possible that the problem is disk-related.
- BenReddMay 21, 2023Aspirant
If I try to browse the drive <IP>/admin or just <IP>, I get the "This site can't be reached " form my windows bowser. I used t be able to get is a couple of months ago. The unit is powered on and lights green. The Icon shows up in my Network connections in the File manager. However, when you click on it it no longer show's you the file folders or any content. This is a mirrored dual RAID....SO How cna I check? Should I update eh firmware?
OK I am not well versed in any LINUX applications. What steps then can I use to get the data? Can I pop the dicks out and insert them in another **bleep** dock and run some program to get copy my files onto another disk?
Hello thanks for the reply. If I try to browse the drive <IP>/admin or just <IP>, I get the "This site can't be reached " form my windows bowser. I used t be able to get is a couple of months ago. The unit is powered on and lights green. The Icon shows up in my Network connections in the File manager. However, when you click on it it no longer show's you the file folders or any content. This is a mirrored dual RAID and my gut is is is the NAS SW and drive data is OK. I just need to get to it...
