BenRedd
May 19, 2023Aspirant
Ready NAS 102 no longer accessable
Hello, I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to g...
May 19, 2023Guru - Experienced User
BenRedd wrote:I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date
Dec 2015 firmware, so yes - very out of date. Current firmware is 6.10.9. Did you ever update it?
BenRedd wrote:
I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to get to my data.
What status is RAIDar giving you?
You want RAIDar 6.5
What happens if you browse to https://nas-ip-address/admin? (using the real NAS IP address of course). Do you get a username/password prompt?
What happens if you enter \\nas-ip-address in the File Explorer address bar? Make sure you use the correct slash (\\, not //).
BenRedd
May 21, 2023Aspirant
Hello thanks for the reply. If I try to browse the drive <IP>/admin or just <IP>, I get the "This site can't be reached " form my windows bowser. I used t be able to get is a couple of months ago. The unit is powered on and lights green. The Icon shows up in my Network connections in the File manager. However, when you click on it it no longer show's you the file folders or any content. This is a mirrored dual RAID and my gut is is is the NAS SW and drive data is OK. I just need to get to it...
