BenRedd
May 19, 2023Aspirant
Ready NAS 102 no longer accessable
Hello, I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to g...
May 21, 2023Guru - Experienced User
BenRedd wrote:
ok thanks. I had to load java first but I got the 6.5 to run. I get a screen that shows the NAS is healthy but if I browse the data if still gives me no data.
Looks like the NAS is running 6.5.2 firmware, so a bit newer than 6.4.1.
BenRedd wrote:
I still cannot browse the admin page via //IP.
Did you try the second step I suggested? That is, entering \\192.168.1.14 into the file explorer address bar?
//192.168.1.14 will open your browser, so you do need to enter \\192.168.1.14
BenRedd
May 22, 2023Aspirant
If I type \\<IP> in File Explorer I get this error:
If I type \\<IP> into a browser I get "page cannot be found" from browser.
If I type // <!P> into a browser I get "page cannot be found" from browser.
