BenRedd
May 19, 2023Aspirant
Ready NAS 102 no longer accessable
Hello, I have a Ready NAS 102 version 6.4.1. It seems maybe the OS is out of date because even though is powered on, I can ping it, my network and computer sees it, it will no longer let me in to g...
BenRedd
May 22, 2023Aspirant
I mentioned in the reply prior that if I type the \\ <IP> in the File Explorer the browser does not open but I get this error:
Yes, I rebooted the NAS. I also tried keeping off for a few days and power on again. No change. Any other thoughts?
May 23, 2023Guru - Experienced User
Thx. FWIW, you said you got a "This site can't be reached" message, which is not something I've seen with file explorer.
I wasn't sure if you meant "internet browser" or "file browser" in your earlier reply.
BenRedd wrote:
Any other thoughts?
I suggest testing the disks in a Windows PC (using either SATA or a USB adapter/dock to connect them). Vendor tools are best (Seatools for Seagate, WD's dashboard utility for WD). Power down the NAS before removing them, and label them by slot so you know where they go.
With the disks removed, you might also power up and NAS and confirm that you see a "no disks" status in RAIDar.
You could also try resetting the admin password back to the default password, and see if that gives you access to the admin web ui. You do that using the "OS reinstall" option in the boot menu. See pages 20-21 here:
Be careful not to do the factory default procedure, as that will reformat the disks and destroy the data.
Do you have a backup of the data?
- SandsharkMay 23, 2023Sensei
Except that you get the user name and password prompt, this sounds very much like you have made changes in your network configuration but the NAS still has a static address for the old configuration. Is your PC's IP address in the 192.168.1.xxx range? The OS re-install suggested by StephenB would also remedy this.
- BenReddMay 25, 2023Aspirant
OK thank you!. I will try these things after the Holiday.
- BenReddJun 26, 2023Aspirant
Hello again. So I finally had time to try all these suggestions. Suggestion using a disk doc did not work. The computer saw the USB disk drive connection and showed me the device. But it never opened a folder or anything in the file manager to allows me to see files. This unit works with other disks I own (Sisun All in 1 HDD Docking).
I tried doing a OS Re-Install. I followed the instructions and it appeared to do something. But then the power button went into fast flashing after awhile and never stopped. I let it sit that way for quite while and then power cycled. Now I just get a slow flashing as if it was in the boot mode. Been that way for 30+ minutes. So far nothing has helped.
I do not have a backup and need the data off the disk. Does anyone know of a paid service that can restore the data for me of a NAS 102? NetGear is not offering that option.
- StephenBJun 26, 2023Guru - Experienced User
The suggestion was to connect the disk to a Windows PC so you could run the vendor diags - Seatools for Seagate, Dashboard, for Western Digital. Windows doesn't recognize the file format, so you cannot offload data that way. But those tools will find the disks, and let you test them.
Since you can connect disks to your PC, I suggest purchasing ReclaiMe You'd need the $200 version.
You can download and see if it can find your files prior to purchase. You can run this with only one disk since you are using RAID-1.
Note you will also need enough storage to offload the data.
Thank you again.
"The suggestion was to connect the disk to a Windows PC so you could run the vendor diags - Seatools for Seagate, Dashboard..."
I have Seagate drives and I did down load the use the SeaTools. The tool saw the disk but when I clicked on quick test it closes/crashes. Also the details never show up for that drive and the other tabs never show any info. The Tool works fine on my working PC disk.
OK so no more OS reinstall suggestions then?
I will check the service out you suggested. It looks like a SW purchase you would use yourself instead of shipping the HD to a provider, correct? Any suggestions on who I can ship this too? Have you used it before?
Did you try both disks in the NAS?
Another possibility is that the adapter/dock isn't working properly.
BenRedd wrote:
I will check the service out you suggested. It looks like a SW purchase you would use yourself instead of shipping the HD to a provider, correct? ... Have you used it before?
Correct. To be clear, I've never used RAID recovery myself. That said, ReclaiMe has been used by other posters here with some success.
No one I can personally recommend. You could contact Seagate.
