Nube09
Sep 27, 2022Aspirant
READY NAS 102
HELLO, CAN SOMEONE HELP ME. MY SON HAS GONE TO STUDY AWAY. AND IT HAS A PROBLEM ACCESSING THE NAS, THE RESIDENCE HAS WIFI. AND YOU CANNOT ACCESS THE NAS AT ANY TIME, BECAUSE IT CAN BE. HOW CAN YOU...
Sep 27, 2022Guru - Experienced User
Do you know how to access the NAS admin web UI?
Nube09
Yes, but it is slow and bad at the file viewing level, since it is via Wi-Fi.
You need the program to work.
To manage the nas from the windows file manager.
- StephenBSep 27, 2022Guru - Experienced User
Nube09 wrote:
Yes
Are you seeing any errors on the log page?
Have you tried rebooting the NAS from the web ui?
Also, what errors are you getting when you try to use file explorer?
- Nube09Sep 27, 2022Aspirant
No, it stays connecting with no results.
If it does not work.
I don't use the file explorer, because it doesn't start the nas from the Readyloud app.
Thank you
Are you saying you use ReadyCloud????
Can you try file explorer? Enter \\hostname in the address bar (substituting the real NAS name for the hostname placeholder). Be careful to use the correct slash - //hostname will launch your browser, which we don't want.
