derekod
Aug 05, 2024Aspirant
Ready NAS Pro 2
My unit is not staying on. When button pushed, solid blue light for about 20 seconds with disk access leds, followed by blinking blue for about 30 seconds, still some disk access lights, then appears...
Aug 05, 2024Guru - Experienced User
derekod wrote:
My unit is not staying on. When button pushed, solid blue light for about 20 seconds with disk access leds, followed by blinking blue for about 30 seconds, still some disk access lights, then appears to shut down. Green com lights are on in back. Occasionally I can see and access the volumes on the drive, but further access times out. Any ideas? Thnx.
Possibly a failing power brick - perhaps worth a risk-buy to see.
Sandshark
Aug 05, 2024Sensei
Does it do the same thing if your temporarily remove the drives?
