rajansharma012
Nov 06, 2019Aspirant
Ready NAS RN 214 Volume Expansion
I purchase a Netgear NAS RN 214 (4Bay) and want to upgrade the HDD as per below : HDD 1 HDD 2 HDD 3 HDD 4 4 TB 8 TB 8 TB Blank HDD 1 and HDD 2 i installed 1 year...
Nov 06, 2019Guru - Experienced User
rajansharma012 wrote:
HDD 1 and HDD 2 i installed 1 year back and now i want to install HDD 3 (8 TB) but why is show grey color.
Is is display in blue color as both of the HDD show after synchronization was completed.
In your screen shot, the array is still resyncing. Wait until that completes, and then let us know if the array looks normal. It will take a while - every sector on all three disks needs to be either read or writting as part of the process. Don't manipulate the disks while this process is ongoing - you can easily lose data if you do that.
It should expand to 12 TB (~10.9 TiB on the web ui). That will happen in two steps - first the array should grow to 8 TB (~7.27 TiB), and then it should expand again to 12.
rajansharma012
Nov 07, 2019Aspirant
Thanks... Thanks... Thanks...
Thanks... a lot
HDD-3 was configured after its array complete.
XRaid give 10.91 TB Space after 20 TB of HDD installation.
Please see the new attachment
- StephenBNov 08, 2019Guru - Experienced User
That is the correct amount (though it actually is giving 10.91 TiB).
The capacity rule for XRAID is "sum the disks and subtract the largest". (4+8+8)=20 TB, and 20-8 => 12 TB. The remaining 8 TB of space is used for RAID parity blocks that give you redundancy when a disk fails (or when storage is expanded).
However, another aspect is that while disk manufacturers use TB (1000*1000*1000*1000 bytes), Windows computers (and the NAS) use TiB (1024*1024*1024*1024) bytes. 1 TiB is about 1.0995 TB. 12 TB is the same as 10.91 TiB.
