rajansharma012
Nov 06, 2019Aspirant
Ready NAS RN 214 Volume Expansion
I purchase a Netgear NAS RN 214 (4Bay) and want to upgrade the HDD as per below : HDD 1 HDD 2 HDD 3 HDD 4 4 TB 8 TB 8 TB Blank HDD 1 and HDD 2 i installed 1 year...
rajansharma012
Nov 07, 2019Aspirant
Thanks... Thanks... Thanks...
Thanks... a lot
HDD-3 was configured after its array complete.
XRaid give 10.91 TB Space after 20 TB of HDD installation.
Please see the new attachment
Nov 08, 2019Guru - Experienced User
That is the correct amount (though it actually is giving 10.91 TiB).
The capacity rule for XRAID is "sum the disks and subtract the largest". (4+8+8)=20 TB, and 20-8 => 12 TB. The remaining 8 TB of space is used for RAID parity blocks that give you redundancy when a disk fails (or when storage is expanded).
However, another aspect is that while disk manufacturers use TB (1000*1000*1000*1000 bytes), Windows computers (and the NAS) use TiB (1024*1024*1024*1024) bytes. 1 TiB is about 1.0995 TB. 12 TB is the same as 10.91 TiB.
