takins
May 05, 2016Aspirant
Ready NAS RNDP6620-100NAS
I cannot find this model on NETGEAR's web site....any idea where I can find info on this model?
May 05, 2016Guru - Experienced User
I agree that it's not there. The Pro models on the support site have -200NAS.
What exactly are you looking for?
- takinsMay 05, 2016Aspirant
Just started with this company and have one of these devices on the network….no password furnished by the outgoing sysadmin. The NAS is on its last leg and I need to access it, but cannot find any info on that model…
- StephenBMay 05, 2016Guru - Experienced User
First of all, stick to one thread.
You have a ReadyNAS Pro-6. You can reset the admin password using the procedure on pages 28-29 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
You want the option to do an "OS Reinstall". That will reset the admin password to "netgear1" and also reset the IP address configuration to use DHCP.
If the system cannot find a DHCP server it will failover to IP address 192.168.168.168. You can directly connect the NAS to a PC (setting a suitable temporary IP address on the PC). No crossover is needed.
After the procedure, you log into the web admin interface (called Frontview) using https://NASIPADDRESS/admin. The software manual might also be helpful - http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Business_SW_05Nov13.pdf
Thank you, I will work this and let the community know succes/failure....
