raafadgie
Jan 27, 2020Aspirant
Ready NAS Upgrade
I'm ready to upgrade my 2 x 2 bay ready nas units to a 626x ready nas 6 bay unit to expand my storage capacity. Can I set the 626x up to show and have 3 x 12Tb drives instead of 1 only and if so is ...
Jan 27, 2020Guru - Experienced User
raafadgie wrote:
Can I set the 626x up to show and have 3 x 12Tb drives instead of 1 only and if so is it difficult ??
Do you mean that you want three separate 12 TB volumes?
Or do you mean that you want 3x12 TB drives in a a single XRAID/RAID-5 volume?
Sandshark
Jan 27, 2020Sensei
Assuming you mean you want three separate volumes, the answer is yes, by putting the unit in FlexRAID mode. Of course, you are eliminating the use of RAID redundancy, putting the data at higher risk of loss due to drive failure.
My main question is why? If your thought it that it would be easy to simply remove a drive and save it as a backup, a NAS is not really intended to be used that way. And if you think reading that drive on another system will be easy, be aware that each will be an mdadm "RAID1" with one missing drive and a BTRFS file system on top of that. Not something your average computer can access.
If you are just looking for more space and don't care if the data is lost, then three separate volumes is certianly better than three concatenated ones (w/o redundancy). If one drive fails, you only lose its contents with separate volumes. With concatenated drives, you lose everything.
