Heavenr
Oct 29, 2019Aspirant
Readyduo RND210 v2 not recognising Powerwalker UPS
HI I've just changed my UPS from a APC to a Powerwalker VI850 LCD and connected the USB Cable to the Readynas. When I boot the readynas the new UPS is not recognised in Frontview. Any ideas? Thank...
Oct 29, 2019Guru - Experienced User
There is no such thing as a "Readyduo RND210 v2". Can you tell us what firmware the ReadyNAS is running? That will tell us what platform you actually have. RAIDar will also tell you: https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
All ReadyNAS use Network UPS Tools (NUT) to monitor the UPS. I am seeing some compatibility issues with the PowerWalker - for instance here: https://github.com/networkupstools/nut/issues/646
Those might be resolved with current NUT software. But if you are running 4.x or 5.x firmware, you have an old legacy NAS - with old NUT software. I don't believe that can be easily updated on the old platforms.
Heavenr
Thanks for the reply. It seems to confirm what I thought that it won't probably work. It's about 8 years old and running firmware 4.1.6 which is the latest for this box. When I installed it I just pluged in the UPS and it worked. I think I was a bit nieve and expected it to work just pluging it into another UPS. I'm planning upgrading the Netgear and got the new UPS first. Should be alright when the Nas gets upgraded.
- StephenBOct 29, 2019Guru - Experienced User
4.1.16 would be the latest. That would make it a ReadyNAS Duo v1.
Heavenr wrote:
Should be all right when the Nas gets upgraded.
Hopefully yes. There are some UPS out there that don't.
