funnybesbes
Jul 22, 2025Aspirant
ReadyNas 102 new hdd not detected
Hello, I just bought a new HDD ( ST2000NT001 - Seagate IronWolf 2 TB) but when I insert it in my readynas 102 it is not detected. I know that this disk is not in the HCL (hardware compatibility l...
- Jul 26, 2025
erf, I reflected a bit over what you said about the disk not getting enough power and I found the cause : I couldn't find the right alim for the nas so I picked something that was matching the connector => a block with 12V - 1A. I tried with another one, this time 12v - 3A and now the NAS can detect the disk (disk led is alight, disk is detected on the web UI).
I feel so dumb --'
Thanks for your help and time.
Jul 22, 2025Guru - Experienced User
funnybesbes wrote:I just bought a new HDD ( ST2000NT001 - Seagate IronWolf 2 TB)
Did you mean 20 TB? Or did you type the wrong disk model?
FWIW, I have see a few posts here from folks using 18 TB drives in their RN102 NAS, but I haven't seen anything bigger.
The NAS will run the short built-in smart test before it adds the drive - have you tried running that on your other PC?
Also, if you use ssh on the NAS, can you see the drive?
- funnybesbesJul 23, 2025Aspirant
No, I really meant 2 TB and I took the reference on the shop where I bought the disk.
Anytools recommended to test the disk on PC, I'm mostly using linux (but can use windows as well) ? is it for using SMART thing to monitor the disk state ?
I used ssh and the disk is not detected in /dev.
But it kinda seems like the disk is detected during the NAS boot process (the disk led is on when the NAS is booting, but after few second ~10s it's going off).
- StephenBJul 23, 2025Guru - Experienced User
My bad, I mentally added a 0 to your model number (ST20000NT001). So the size certainly is not the issue.
I suggest using Seatools to check it.
It's available for both Windows and Linux platforms.
I assumed you did, I should have emphasized a bit more on the model number ^^'
Anyway, I ran seatools with the "quick test" feature, it passed without any error or warning (the disk is new so I wouldn't have expected otherwise). I can run an extended one if you want.
