CalebCPI
Jul 14, 2022Aspirant
ReadyNAS 102 not displaying files while also reporting 2/3 of the storage drives are full
I'm a little stumped, so I'm coming here for help. I work closely with a photography business, and recently while setting up a new NAS, they reported not being able to access files on their old NA...
CalebCPI
Jul 15, 2022Aspirant
This makes sense, but I haven't been able to restore anything effectively. Either the restores I initiate fail or they do not provide me with any additional files. I also checked the log files and can't find anything productive to suggest that the loss of data was initiated by an action with shares or drives. I spoke with someone from the business and they explained that this drive is very infrequently accessed, but it likely stopped working after some rearranging. I'm assuming they pulled the power instead of letting it shut down gracefully, so I also wonder if anything is stored on volatile memory that's necessary to access this data.
Jul 15, 2022Guru - Experienced User
You could also try ReclaiMe - connecting a disk to a Windows PC.
- CalebCPIJul 18, 2022Aspirant
Is this by any chance a free utility, or does this need a license to do what I am looking for. Also, do you by any chance know what format the file structure is in? Would I be able to view this drive in a Linux distribution?
- SandsharkJul 18, 2022Sensei
ReclaiMe is not free, far from it, but there is a free version you can use to see if it'll do what you want it to.
The RAIDs on OS6 are MDADM and the file system is BTRFS. But if you can't get the volume to mount using the Linux installed on the NAS, it is unlikely you'll have more luck with another distro.
