thatanos
Jun 12, 2018Aspirant
Readynas 102 unavailable after some hours working
hello, after using some differents Readynas (Since redaynas duo, to 102-202 nas 104) Now I´m having and issue with a 104 (equipped with 2 WD RED for NAS 6Gb) and firmware 6.9.3
Since 4 or 5 wee...
thatanos
I´m using 6.9.3 firmware, as it isn´t accesible via lan, but some times the webpage admin is accesible but not responding for switching off or other options.
Jun 12, 2018Guru - Experienced User
Can you download the log zip file?
- thatanosJun 12, 2018Aspirant
sure, the system logs from registry page isn´t it? looking at the page I can´t anything strange. las time I have to switch it off was like 6 hours ago.
I have it, wich one will you need? as the forum didnt allow me to post it as it a zip file.
- StephenBJun 12, 2018Guru - Experienced User
You shouldn't post them publicly as there is info in them that could potentially be used to identify you. There is a process to get them to mods here: https://kb.netgear.com/21543/How-do-I-send-all-logs-to-ReadyNAS-Community-moderators However, I'm not a mod. Perhaps PM mdgm-ntgr and ask him if he'd like to take a look.
I suggest checking the ethernet statistics for errors (collisions, errors, dropped packets, etc). They are in network_settings.log.
Also, open volume.log and scroll down to the === df -h === section, and look at the /dev/md0 line. It's normally about 25% used, and if it gets too full the system will misbehave. Also, scroll down further to === df -h === and look at the inodes used on /dev/md0. Usually that will say only 1% of the inodes are used.
You could also browse system.log and kernel.log, looking for any crashes (perhaps related to ftp).
Did this begin right after you upgraded to 6.9.3?
- thatanosJun 14, 2018Aspirant
sorry bur yesterday I post 2 times but someone delete my post as I have publish part of the logs ( withour any personal info)
I have been working with 6.9.3 since 1 weej after it has been release without any problem till 5/6 weeks ago.
