SteveW01
Dec 20, 2019Aspirant
ReadyNAS 102
I need some help please. I have just purchased a used Netgear Ready NAS 102 and I'm having trouble getting it setup. I've followed the instructions yet ready cloud still doesnt discover it. I have r...
- Dec 20, 2019
SteveW01 wrote:
However as I purchased the unit from a company called CEX (Computer Exchange) it is a used item. I've tried to register the unit and it's telling me that its registered to another user.
When I run RAIDar all I get is a screen telling me the details of the unit, nothing else.
Note quite nothing - it is showing you a TFTP_REQ status. That means that something isn't right with the internal flash memory.
You could try doing a USB recovery. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
Note you need to follow the instructions for the ARM-based system at the bottom. Generally older thumb drives work better than newer ones (and you might need to try more than one).
If that fails, then I suggest returning the unit to the seller.
Sandshark
Dec 20, 2019Sensei
Do you intend to use ReadyCloud for remote access? Although Netgear pushes the use of ReadyCloud for set-up, it is not, IMHO, the best way to do it. Using the local admin GUI is best (press Admin Page in RAIDar). If you do need remote qccess, troubleshooting the ReadfyCloud problem should be easier with the NAS initilized.
