SteveW01
Dec 20, 2019Aspirant
ReadyNAS 102
I need some help please. I have just purchased a used Netgear Ready NAS 102 and I'm having trouble getting it setup. I've followed the instructions yet ready cloud still doesnt discover it. I have r...
- Dec 20, 2019
SteveW01 wrote:
However as I purchased the unit from a company called CEX (Computer Exchange) it is a used item. I've tried to register the unit and it's telling me that its registered to another user.
When I run RAIDar all I get is a screen telling me the details of the unit, nothing else.
Note quite nothing - it is showing you a TFTP_REQ status. That means that something isn't right with the internal flash memory.
You could try doing a USB recovery. https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
Note you need to follow the instructions for the ARM-based system at the bottom. Generally older thumb drives work better than newer ones (and you might need to try more than one).
If that fails, then I suggest returning the unit to the seller.
Dec 23, 2019Guru - Experienced User
SteveW01 wrote:
OK - I've now purchased a brand new RN212. The unit is up and running, however since doing the update i'm now unable to access the admin page and I'm getting the attached message.
Did you migrate the disks or did you start with a factory default?
Are you seeing signs of disk activity?
SteveW01
Dec 24, 2019Aspirant
I installed then then done a factory reset to wipe the disc's.
I have activity on the NAS and I've managed to migrate my data. The ready NAS can be seen on the network by all devices and the TV streams my video and likewise with SONOS & my music. I just cant access the admin page to change any settings.
Thanks
Steve
- StephenBDec 24, 2019Guru - Experienced User
Are you using https://nas-ip-address/admin in the browser?
Does RAIDar indicate that the array is still syncing?
You could use your courtesy phone support to resolve this (via my.netgear.com)
- SandsharkDec 24, 2019Sensei
Since the NAS has a self-signed SSL certificate, too-harsh security settings and/or a virus or malware protector can block it.
- SteveW01Dec 27, 2019Aspirant
I'm going to open a new thread over the coming days as I've returned the NG 102 and brought a brand new RN212. Thank You everyone for your help.
Steve
