Sollman's avatar
Sollman
Follower
Apr 03, 2021
ReadyNAS 102
Flawless function for several years.  Lightning strike in close vicinity of home last weekend affected a GFI outlet in my barn and the router plugged into it.  Also apparently hit my readyNAS.  NAS will no longer turn on.so cannot tell what I have for data.  Any way to try to recover that data from the disks if they are still functional?
  • StephenB's avatar
    If you get a new (or used) OS-6 ReadyNAS, you can migrate the disks to it.  If the array is functional data will be preserved.
    You can also purchase RAID recovery software that supports BTRFS, and off load data that way - for instance, ReclaiMe.  https://www.reclaime.com/
    The volume can be mounted for free on a PC running linux, and there are also mdadm and btrfs beta packages that should let you mount them for free in Windows also.
    If you do decide to replace your NAS, I suggest that you put a backup plan in place.  Devices can fail without warning (or get stolen, etc).  The best way to protect it is to back it up.
  • Before you invest in anything, do you have the ability to test the drives with the vendor's tool?  If the volume is damaged, it's likely because the drives are damaged, not that the data just got corrupted.
    If the drives pass vendor diagnostics, the issue could just be the power supply.  NAS with external supplies, like your 102, are fairly well isolated by the supply from events like that.  It's just a basic 12V 5A supply with a standard 5.5mm x 2.1mm connector.  Some of the cheap supplies can't provide good initial inrush power, so choosing a 6A or 7A can be good if you are using drives that require a lot of power to spin up, like enterprise models.  I recommend you look for one that expressly states that it's also for CCTV cameras or some device other than LED lighting.  LED lighting doesn't require the same level of regulation as most other complex electronic devices.
    If the drives can't pass vendor diagnostics, then the surge did get into the NAS chassis, and it's unlikely anything will help.  But if at least one passes, then recovery may still be possible.
    Unfortunately, though, the other thing on the NAS that is subject to damage by a lightning event is the network transceiver.  A power supply may get the NAS booting again and still leave you with no way to get to the data.  This is more likely if you have an Ethernet cable running from your house to the barn and no switch or Ethernet surge protector in the barn.
ProSupport for Business
