John-aus
Jan 31, 2023Follower
ReadyNAS 104 error - Remove inactive volumes to use the disk. Disk #1,2,3,4
Looking for HELP as I have run out of options. I have a very similar issue to the following on this forum. Solved: Re: Remove inactive volumes to use the disk. Disk ... - NETGEAR Communities ...
NiveditaP
Feb 07, 2023NETGEAR Employee Retired
Hello John-aus ,
And welcome to the NETGEAR Community! 🙂
The disks you are using in your NAS seems to be faulty. You can check the same from the disk.log info from the system log file. If you get an ATA Error count greater than zero then the disk is faulty.
Have a lovely day,
NiveditaPa
Netgear Team
Sandshark
Feb 07, 2023Sensei
Do not purchase Gearhead support. They do not provide support for ReadyNAS and getting your money back once they inform you of that will be difficult.
