Sgt_Torpedo
Nov 01, 2015Aspirant
ReadyNAS 104 Lost Array After Upgrade To 6.4.0- Any Way To Recover?
I have a ReadyNAS 104 with 2 WD Red 3TB drives. I am using the factory recommended X-RAID setup. After the reboot in upgrading to OS 6.4.0 the system reports an inactive volume on disks 1&2. Is there...
Nov 01, 2015Guru - Experienced User
I think your issue is one of several bad outcomes from the 6.4 upgrade.
I'd contact support, and make it clear that since it is upgrade-related there should be no charge.
- kpurcellNov 03, 2015Tutor
Makes you wonder if they even beta tested this version of the firmware?! I have been waiting for days for it to complete the upgrade. Once done, beware rebooting the NAS as it seems to continue an upgrade making it pretty much unaccessable durign the process.
- mdgm-ntgrNov 03, 2015NETGEAR Employee Retired
kpurcell, this firmware did undergo a beta test.
Determining what caused Sgt_Torpedo's problem would require some diagnosis.
