Ciospy
Jul 06, 2016Aspirant
ReadyNAS 1500 rack mount legacy
hello, I bought this used nas, I took two hard drives western digital enterprise WD2003FYPS-27Y2B0, at the end of the creation of the volume x-RAID2 me error and goes to degrade mode, the disks are n...
- Jul 14, 2016
Solved, now the nas works well with 3 hard drives, so it solved the problem. Thank you all
Jul 07, 2016Guru - Experienced User
What does the web admin page (or RAIDar) say about the disk health? Can you see SMART stats for both disks?
Ciospy
Jul 07, 2016Aspirant
no, you can not see the smart was because the first disc is inactive and the second reserve, I tried several times to create the new volume, but same result.
With only the nas hard work and smart status is ok.
- StephenBJul 07, 2016Guru - Experienced User
You could try doing a factory reset with only one disk in place. If that works, then try hot-inserting the second drive and see what happens.
It is possible that the used unit is defective, it is also possible that one of the drives is failing.
- CiospyJul 07, 2016Aspirant
I have also tried to enter the second heat disk, but the same result. the discs are new. With only one hard drive works well and there is no problem. It may be the firmware nas?
4.2.28 is current firmware, and quite stable. You could try overinstalling it from the admin web ui. But I am wondering if you purchased a defective chassis.
Are you always using the same drive bays? Maybe try different ones?
