Ciospy
Jul 06, 2016Aspirant
ReadyNAS 1500 rack mount legacy
hello, I bought this used nas, I took two hard drives western digital enterprise WD2003FYPS-27Y2B0, at the end of the creation of the volume x-RAID2 me error and goes to degrade mode, the disks are n...
- Jul 14, 2016
Solved, now the nas works well with 3 hard drives, so it solved the problem. Thank you all
Ciospy
Jul 07, 2016Aspirant
sure, I try this, if still does not work? nas is damaged?
Jul 07, 2016Guru - Experienced User
It could be. Maybe one of the netgear folks will share their thoughts.
- CiospyJul 08, 2016Aspirant
I noticed a small my mistake, it could be that the hard drives are not compatible? my model is WDC WD2003FYPS, netgear in the compatibility list is the WD2003FYYS. Can this be the problem? thank you all
- StephenBJul 08, 2016Guru - Experienced User
Possible I guess, but I think the WD2003FYPS should also work.
I tried it with an old hard disk with 620 GB on the first slot and a second slot on wd2003FYPS and works, he has configured x-raid properly. Do you think if I put in the first slot wd a red 2TB efrx and other I keep wd2003FYPS can Work? thank you
It should work, and expand the volume to 2 TB. That will take a reboot after the initial sync.
- CiospyJul 14, 2016Aspirant
