Ciospy
Jul 06, 2016Aspirant
ReadyNAS 1500 rack mount legacy
hello, I bought this used nas, I took two hard drives western digital enterprise WD2003FYPS-27Y2B0, at the end of the creation of the volume x-RAID2 me error and goes to degrade mode, the disks are n...
- Jul 14, 2016
Solved, now the nas works well with 3 hard drives, so it solved the problem. Thank you all
Jul 08, 2016Guru - Experienced User
Ciospy wrote:
I tried it with an old hard disk with 620 GB on the first slot and a second slot on wd2003FYPS and works, he has configured x-raid properly. Do you think if I put in the first slot wd a red 2TB efrx and other I keep wd2003FYPS can Work? thank you
It should work, and expand the volume to 2 TB. That will take a reboot after the initial sync.
Ciospy
Jul 14, 2016Aspirant
