Garrfish
Mar 01, 2016Aspirant
ReadyNAS 202
Can folders with many files be transfered at one time? In other words I have many video files within a folder and sub folders as well. It would be a pain to cerate seperate folders and then copy file...
sharpycl
If I understand the question correctly then yes a folder with many files can absolutely be transfered all at once. The more files in one folder the longer it will take for a transfer over a network to complete. If the transfer is occuring from one folder to another on the ReadyNAS than it should happen fairly quickly.
Hope this helps.
BrianL2
Mar 01, 2016NETGEAR Employee Retired
Hi Garrfish,
Welcome to the community!
I agree with sharpycl. Why won't you just create a new folder on your PC and compile all the files that you want to copy or transfer to your ReadyNAS. A backup job, would be much easier and faster rather than copy and paste through Windows explorer.
Kind regards,
BrianL
NETGEAR Community Team
- Apr 03, 2016Retired_Member
