Artanis
Feb 18, 2021Tutor
ReadyNas 214 - BTRFS error during scrub - Stuck in readonly
Hello everyone. I hope you can help me out... on Febraury 15 my ReadyNas 214 (4x8TB) started its scheduled scrub. After a couple of days I noticed I couldn't add new files in the NAS and realized th...
- Feb 18, 2021
Artanis wrote:
Feb 15 08:16:44 ArtanisNAS kernel: BTRFS: error (device md126) in btrfs_commit_transaction:2233: errno=-5 IO failure (Error while writing out transaction) Feb 15 08:16:44 ArtanisNAS kernel: BTRFS info (device md126): forced readonly Feb 15 08:16:44 ArtanisNAS kernel: BTRFS warning (device md126): Skipping commit of aborted transaction. Feb 15 08:16:44 ArtanisNAS kernel: BTRFS: error (device md126) in cleanup_transaction:1856: errno=-5 IO failure Feb 15 08:16:44 ArtanisNAS kernel: BTRFS info (device md126): delayed_refs has NO entry Feb 15 08:16:45 ArtanisNAS kernel: BTRFS warning (device md126): failed setting block group ro, ret=-30 Feb 15 10:09:28 ArtanisNAS kernel: BTRFS error (device md126): bad tree block start 11025967846460254743 18195154993152
Feb 18 09:44:56 ArtanisNAS kernel: BTRFS error (device md126): bad tree block start 11025967846460254743 18195154993152 Feb 18 09:44:56 ArtanisNAS kernel: BTRFS error (device md126): bad tree block start 11025967846460254743 18195154993152
You ended up with a corrupt file system.
The best thing to do is back up all your files, then do a factory default from the system->settings page.
That will re-format everything, so you will need to reconfigure the NAS from scratch (and reinstall your apps). Then restore the files from the backup.
Feb 18, 2021Guru - Experienced User
