Les214
May 21, 2020Aspirant
ReadyNAS 214 - replacing disks with larger disks
I have been running this NAS with 4 - 2TB drives and it was up the 75% full. So I bought 4 new Seagate Ironwolf 4 TB drives. I replace the first drive and it took about 16 hours to resync. I repla...
May 22, 2020Guru - Experienced User
Les214 wrote:
With their lights slowly flashing, are they doing backups,
Possibly. Check the status on the backup page in the web ui.
Les214
May 22, 2020Aspirant
The NAS is back up and running. The shutdown never happened. Thanks to the last post, I was able to access the NAS through the Web UI. I checked the backups and they were all fine. Then I ejected both external drives and physically removed them. Then I tried to do a reboot from the Web UI, but that did not work. So finally I pulled the power, waited 30 seconds and pluged in the power. The NAS booted fine. everything was healthy, so I pulled Drive 3 and put in the new 4TB drive and the NAS started to resycn. I won't rush the process.
The first reply above mentioned being concerned about replacing all the drives ate the same time with the same drives. While I can understand the logic of that concern, I would prefer running all the same make and model drives as I feel the performance of all drives should be the same and they should all work together in the NAS.
Thank you all of you that helped me through this upgrade.
Les
