tomino
Nov 08, 2023Aspirant
ReadyNAS 214 after reboot 'Remove inactive volumes to use the disk #1.2
Hello I have a problem with my ReadyNAS 214 it has 3 2TB WD Red HDD in it running RAID5. I haven't used it for a year and i rebooted it yesterday and after that i got the error message 'Remove inac...
Nov 08, 2023Guru - Experienced User
tomino wrote:
i messaged support and they told me to turn off the raid and remove all disks and put them in again. Turn it on again and update the firmware to the latest version.
Not the best advice, and hopefully did no harm.
Download the full log zip from the web ui.
If you'd like I can take a look at the zip. If you want to proceed with that, then put it zip in cloud storage and send me a download link via private message (PM). Send a PM using the envelope link in the upper right of the forum page. Make sure the link permissions allow anyone with the link to download.
- tominoNov 08, 2023Aspirant
yes i hope it doesn't make it worse
well i found the download logs button, but where do i find the cloud storage?
the zipped log is 2.4MB
thank you
- StephenBNov 08, 2023Guru - Experienced User
FYI, dropbox, google drive, icloud, onedrive all work (as do several others).
- SandsharkNov 09, 2023Sensei
The reason you are seeing two volumes is that the OS can't figure out how to concatenate all the drives into one. So, it see's two data volumes. But since there cannot be two volumes with the same name, it is calling one data-0 (which is the name of the MDADM RAID on which the BTRFS volume resides) Both of these contain your data, though fractured such that you can't get to it. So, whatever you do, don't think that destroying one will help. That would actually make recovery impossible, which StephenB hopefully can help you with once he looks at your logs.
