AnandSharma's avatar
AnandSharma
Follower
Feb 21, 2019
Readynas 214 (Inactive Disks)
Hi  I seem to have messed up ReadyNas. I had 2 HDD of 4 tb each with 2.71 tb of data under Raid 1. I tried to upgrade it with adding 2 more HDD of 4 tb each and change it to Raid 5. While it was Re...
  • StephenB's avatar
    Feb 21, 2019
    Are you saying that the volume is inactive on the volume page?  If so, the best option is to use paid support (my.netgear.com).  Ask about per-incident support.
    If the volume is active, then are you able to access the files with file explorer (or finder if you have a Mac)?
