zabirhakim
Sep 27, 2021Aspirant
ReadyNAS 312 - Extend Partition
Hi all, Would be great if something can assist. I have a RN312 with new 2 x 6TB HDD, however the NAS is showing only 1TB of total available space, please can some advise how I can expand the v...
- Sep 27, 2021
It is supposed to work the way you expected, so we have to figure out what it is that's stopping it from doing so. The first thing I suggest is toggling off and then back on XRAID. If that doesn't kick it off (give it a few minutes), try re-booting again.
There is some information available either via SSH or in the downloaded .zip file that might give a clue as to the nature of the problem.
Using cat /proc/mdstat from SSH or looking in mdstat.log, how many volumes do you see? You shoud have an md1, md1, md127, and md126, but you probably only have the first three.
Using btrfs fi show or looking in btrfs.log, there should be an entry for the data volume something like this (numbers will differ on yours, this is mine):
Label: '7fc780f2:data' uuid: 9ad0e5b9-a030-4530-a93c-6a337693158d Total devices 2 FS bytes used 22.66TiB devid 1 size 27.27TiB used 22.78TiB path /dev/md127 devid 2 size 3.64TiB used 1.03GiB path /dev/md126
The contents of sgdisk.log and/or partitions.log or output of fdisk -l may also help.
There is a command from SSH that might help: volume_util -e auto
zabirhakim
Hi Sandy,
Yes I did, may be I was mistaken and assumed that if I extend to a 6TB and then eventually change both the drives to 6TB, restarting the NAS would recognise that the drives are in fact larger.
Is there any way around this without a factory reset?
Thanks,
Zabir.
Sandshark
Sep 27, 2021Sensei
- StephenBSep 27, 2021Guru - Experienced User
Note the screenshot shows that the volume is degraded. So something likely went wrong with the expansion.
- SandsharkSep 27, 2021Sensei
I did miss that important tidbit. I didn't expect both drives to be blue in that case. Now, I'm thinking something may have wrong with the RAID sync of the second drive with the 1TB partition before it even got to expansion. The data I asked for should help determine where the process failed.
- zabirhakimSep 28, 2021Aspirant
Hi there, really appreciate you coming back to me. Unfortunately something else went wrong with the NAS after I restarted it, it was asking for the drives to be reinserted so that a new volume can be created, I think something really bad went wrong something. Fortunately my NAS syncs to the cloud so I can retrieve all the data, downside is that it's 4TB, hence the reason for trying to get it to work without formatting. I ended up creating new volumes and the sync is now running, it'll probably take a day or 2 to sync it with the cloud. Would've been good to see what went wrong though but unfortunlatey the logs have been cleared too, so sorry. I did find one issue though, one of the disks (as you mentioned) was showing up degraded, it was throwing ATA errors, may be that's a failsafe in the ReadyNAS. I spoke with WD and they said ReadyNAS tends to throw these errors, I should try and format and try again. Creating a new volume after the NAS threw the volume error seems to have resolved the ATA error issue to, hopefull it stay that way, if not I'll raise and RMA request, it is afterall an enterprise gold disk.
Thanks once again :-)
