Remital
Mar 17, 2016Aspirant
ReadyNAS 312 showing space used for snapshots when snapshots set to never
I have recently upgraded from ReadyNAS102 to ReadyNAS 312. Snapshots are set to never yet space is being used. This also happened on the 102. There are no snapshots on the timeline to delete. Fro...
- Mar 19, 2016
Please check your private messages. I have sent you a Private Message. I assume you want all the snapshots that were not upgraded to be deleted?
mdgm-ntgr
Mar 18, 2016NETGEAR Employee Retired
This is because there were snapshots that were not upgraded when you updated from 6.1.8 to 6.2.5.
I can fix this for you.
- RemitalMar 19, 2016Aspirant
Thank you , how can it be fixed? what do I need to do to allow you to fix this??
- mdgm-ntgrMar 19, 2016NETGEAR Employee Retired
Yes please delete all snapshots. I have sent a reply to your private messages.
Thank you
- Jun 06, 2017Retired_Member
