davila917
Mar 20, 2016Aspirant
ReadyNAS 314 LCD Displaying Memory Error
I have a brand new readynas 314 updated to the latests OS 6.4.2, I believe. I've only had it for no more than 1.5 days and this morning I see the LCD displaying weird characters. I couldn't access ...
- Mar 20, 2016
Memory Error with no ability to use the boot menu appears pretty clear cut. Most likely either a problem with the memory (RAM) or the memory coming loose in shipment.
With a recent purchase if you can return it to your reseller in exchange for a new unit that would be best.
If you were seeing e.g. "Out of Memory" that would be a completely different issue and wouldn't suggest bad hardware.
BrianL2
Mar 20, 2016NETGEAR Employee Retired
Hi davild917,
Could you post the exact error message that showed up on the LCD screen? If there are data or files that you need to access, try to back them up while the unit is in Volume Read Only mode (steps are found here).
Looking forward hearing your feedback.
Kind regards,
BrianL
NETGEAR Community Team
davila917
The exact error message is: Memory Error. That's it. Nothing more than that.
I already tried to reset the system by following the steps and it wouldn't reset. It stays on that error message.
