davila917
Mar 20, 2016Aspirant
ReadyNAS 314 LCD Displaying Memory Error
I have a brand new readynas 314 updated to the latests OS 6.4.2, I believe. I've only had it for no more than 1.5 days and this morning I see the LCD displaying weird characters. I couldn't access ...
- Mar 20, 2016
Memory Error with no ability to use the boot menu appears pretty clear cut. Most likely either a problem with the memory (RAM) or the memory coming loose in shipment.
With a recent purchase if you can return it to your reseller in exchange for a new unit that would be best.
If you were seeing e.g. "Out of Memory" that would be a completely different issue and wouldn't suggest bad hardware.
davila917
I cannot get to the boot menu at all. It won't get past the error message. I'm already requesting an RMA. I don't want to open the device since I bought it within a couple of weeks.
mdgm-ntgr
Mar 20, 2016NETGEAR Employee Retired
