Johnny99111
Dec 05, 2016Follower
ReadyNAS 314 Out of memory isra 13+31c
l have 6 of these of the exact model and all contain 4 WD RED 2 TB drives. Only one hasn't given me this error and its running FW 6.4.0. All the others are a mix of 6.5.1 and 6.6.0. I've backed up...
mdgm-ntgr
Dec 05, 2016NETGEAR Employee Retired
So all 6 are ReadyNAS 314 units?
What services are you running on these?
Are there any apps installed?
Have you opened any support cases about this?
Can you send in the logs (see the Sending Logs link in my sig) from a system that is exhibiting this problem? If you can't boot it normally you should be able to grab the logs when booted into volume read-only mode.
